having trouble with trimming to a curve then aligning
Hi
I'm still somewhat of a rookie with NX, so apologies if the question is really easy.
I have an offset hole that is coming into the outer body at 35 degrees, I'm trying to place a inlet tube into that hole (which I've had no problem doing). I can't seem to get the tube to be either trimmed in a way so I can face blend the inner side of the outer body with the inlet tube. I've tried just using a simple datum plane, but that doesn't seem to work. I can't seem to get a datum plane to follow the inside curve of the outer body, even if I do it completely separate from the assembly.
If I use an extrusion to subtract the portion, it won't let me use some of the assembly contraints.
Any advice?
Any advice?
RE: having trouble with trimming to a curve then aligning
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
