Transformer problem
Transformer problem
I have a Tranny with primary side 110v/230v and secondary side 16v/16v and 32v center tap. Problem is the first coil on the primary side is burnt out but the second coil is ok which is 320ohms on the primary side. Could I put a 320ohm resistor on the burnt coil to lower the voltage to 115v to the second coil so I can still get voltage out the secondary side coil. When tranny is on the control card and the jumper is set to 115v only one coil is used on the primary side they arnt connected in parallel. Any help appreciated as this card cost $1200.
RE: Transformer problem
Next best option is to purchase an equivalent transformer with the same output voltages, etc.
The card may be worth $1200, but a transformer shouldn't cost that much.
In answer to your question, a resistor is a bad idea for several reasons. Perhaps a 240-to-120 'travel' transformer would be a better approach (not the diode version, the transformer version).
It's not recommended. The transformer with one winding damaged is 'walking wounded'. You don't know what other internal effects the damaged caused, perhaps it's nearly shorted primary to secondary. It's higher-than-acceptable risk to keep on using it.
http://www.signaltransformer.com/
or
http://ww
Signal sells direct in units of one. I have repaired many boards using them.
You cannot use the DC resistance of the single primary as the replacement value for the primary. If you must use this board, find a 220 to 120 transformer and power the remaining primary. As noted above, this is a dangerous long term fix, as you don't really know when the damaged transformer will fail.
Steve
Bill
"Why not the best?"
Jimmy Carter
