API 610 VERTICAL PUMPS
can anyone advise vertical plane tolerance required relative to horizontal datum, for barrel installation before final grouting?
RE: API 610 VERTICAL PUMPS
For the leveling of the barrel ( suction casing ) of a vertical pump VS6 type, the reference is always made to the horizontal surface of the barrel ( suction casing ) supporting the discharge head. The pump vendor should provide such requirement in their IOM.
