Sheet Metal Want Flatten
Attached is a rolled cylinder with different diameters. We use to seam weld all 3 components but now the cylinders are all spun rolled and then seam welded to make on complete part. The problem is I can get solid works to flatten the pattern. Please Help!
RE: Sheet Metal Want Flatten
Actually, the first thing you might want to do is check out the help files on sheet metal parts.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
