Help needed using lbs/minute per square inch of shank
Fist of all, thank you for viewing this thread and for any help that you may provide.
I need to figure out a load rate for a test, can you help by providing me with the formula? The calculation is as follows:
The test has to be done at rates producing 100,000 lbs/minute per square inch of fastener shank area. The fastener shank diameter is .132, area is 0.013685.
Again, thank you for your help.
RE: Help needed using lbs/minute per square inch of shank
100,000 lbs/minute per square inch x 0.013685 sq in = 1368.5 lb / min.
Mike
Thank you Mike, I feel so silly right now.
Have a great day.
Yeah, I never have days like that:)
