Freeform objects in Solidworks
I have just imported a 'free-form' object from Solid Designer into Solidworks +2001. It is symmetrical and has three sections on either side. It is free-form because I want it to appear as a squashable material. However, I want to divide the free-form object into two along the sections with a workable plane/line so i can draw away from the imported drawing. I've seen a thread this morning that talks about using planes to 'cut' existing sections but I was wondering if there was another way without actually splitting the sketch?
RE: Freeform objects in Solidworks
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
