Message during closed part
when I close an assembly, the message appear when I close the assembly.
Can I avoid this message ?
If the assembly contain a lot of parts....this message become very, very annoying.
I set like the image attached, but nothing, the message remain after closed and open again NX.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Message during closed part
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I've not upload correctly all images.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
I would rather be told some component has changed and have the opportunity to save my work than lose it like the CAD system I use now does. I get one question when I exit, Are you sure? How try to figure out if some component was changed and you forgot to save it.
Ben Loosli
This message exits on close assembly part that is in read-only when contained part was modified from the last saved.
On a big assembly there are lot and lot of this message and on closing I click on the mouse 150 time.
Solutions ?
Thank you...
this message is not the case that you describe.
This message exit on read-only assembly with read-only part that was modified from the last assembly saving.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
1) Save the big assembly without message
2) Close the big assembly with the X icon
3) Messages appear for each read-only sub-assembly that as modified part after when the sub-assembly become read-only(approved).
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
with your suggestion I've found the solution.
Thank you a lot.
Thank you...
