UNDERGROUND CONCRETE VAULT DESIGN
HI,
I relatively new to designing vaults and dealt mostly with building above ground.
Does anyone recommend any good standards for the design of the vaults for uplift, active and at rest pressure and what is a conservative seismic load on the tank??
Thank you,
MAP
Thank you,
MAP
RE: UNDERGROUND CONCRETE VAULT DESIGN
I do not know the size of your vault or vaults, but would highly recommend engaging the services of a geotech if it is a detention tank.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
If you have a decent depth of soil over the tank, uplift should not be a factor, but it still needs to be checked.
Mike McCann
MMC Engineering
Motto: KISS
