Expression in Sketch
I am using Tool - 'Expression' to creat a profile using data..
i have given a expression like SG_X_PP000 = 6,631, SG_X_PP001 = 6,439, SG_X_PP002 =...... etc.'
Than i have clicked Spreadsheet Edit in expressions command to add remaining data. Please the spreadsheet attached.
When i save and exit from spreadsheet but the data will not be updated in Expression command.... Please can anyone help........
Cheers,
Lokesh
Cheers,
Lokesh
RE: Expression in Sketch
It's simple when you know how, but I was puzzled before I found out - before you close the spreadsheet, click Tools > Update Expr
I told you it was simple!
Cheers,
Jon
What you do is select the cells which contain all of the expression definitions (name and values) and then select the 'Define Expr Rng' function on the 'Add-Ins' tab on the Modeling Spreadsheet. Now you can select the 'Update NX Part' function, close the Spreadsheet (be sure to save it) and when you return to NX, your new entries should now be there when you open the Expression tool.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
