Lathe Fanuc Post Question?
I have a lathe that uses FanucOT ie it uses G32, G76, G92 for threading and U and W for incremental.
I created a new post within postbuilder and selected the fanuc generic post as a stating point but this post issues the G33 for thread cutting and G90/G91 for absolute/incremental modes.
Am I using the incorect pui and if so could someone sugest what is required to create the correct post output?
Kind Regards,
S
RE: Lathe Fanuc Post Question?
It has been a long time since I have seen a 0M control.
If I recall the G76 is a thread cycle and not supported by Post Builder.  You can change the G33 to a G32 from the Lathe Thread event under Motion.  I am not sure if the I and K are for increment but it is worth a try.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
Thanks for your reply John.
I'll give what you sugest a try.
BTW could the post potentialy be edited manualy so as to OT /OM funtionality or is just flat out not supported within NX?
Apologies for the newbie questions.
Kind Regards,
S
'Yeterday, I could not spell engineer. Today, I are one!'
I suppose you could do almost anything in the post with enough customization.
John Joyce
NX6.0.5.3
