Apply rotated displacements???
Hi, hope someone can help.
I need to apply a fixed displacement to a pipe rotated through 45 degrees. The displacement will be in the perpendicular directions. The pipe is free to expand axially.
Any ideas?
When i try and apply nodal displacements (in global coordinates) the pipe gets restrained axially.
Andrew
RE: Apply rotated displacements???
Displacements ARE boundary conditions.  If you want a particular "degree of freedom" to be free, leave "that" displacement field blank.
"Blank" = free
"Zero or some other value" = fixed at that magnitude
Richard Ay
Intergraph CAS
