Slip on Flange Tolerance Calculation - Loose Fit on Pipe?
I am calculating the tolerances for a 1/2" slip on flange used on 1/2" pipe.  I end up with what seems like a fairly significant amount of play in the assembly if the flange would run its maximum size and the pipe would run its smallest size.  I calculate about 0.100 of an inch of play.  Is this typical?
RE: Slip on Flange Tolerance Calculation - Loose Fit on Pipe?
That's just about the only reason that a slip-on flange is valuable...
