Benefits of higher frequency wireless cameras?
Hey guys,
I always wondered. Is there any benefit for a device to be on the 2.45ghz bandwidth as opposed to like say 0.9ghz? I'm thinking of buying a wireless camera and there are 2 options for frequency.
RE: Benefits of higher frequency wireless cameras?
If it was me, I'd get a WiFi version of the camera (not just 2.4 GHz, but specifically Wifi enabled). They're not that much more expensive.
The 2400MHz camera might have better video quality given the higher bandwidth avaialble of the band.
I guess it comes down to what you need, longer distance or greater flexability.
Smaller antenna, more bandwidth. More likely the modulation method is digital due to more modern chips being available and due to fact that 2.4 GHz is a recognized band worldwide (i.e. manufacturers will invest more in doing a chipset right) Digital modulation gives better reception and more immunity to other devices in the same band. Little less range at the higher frequency. The band is getting a somewhat crowded with other devices.
900MHz
The band is not as wide, so bandwidth of a design may be reduced. This band is primarily North America only (the 868 ISM band of Europe is too narrow to support video). Slightly less attenuation at this frequency, so more distance for the same transmitted power.
I guess that would be the same thing as the size of a channel?
If this is correct, then how would you go about figure out the available bandwidth at each region? I looked at the FCC Table of Frequency Allocations, and wasn't sure how to get the information.
E.g. "Part 15" for the USA: http://en.wikipedia.org/wiki/Title_47_CFR_Part_15
(The above Wiki link is intended to help you get started. Obviously one would not rely upon the information on Wikipedia except as a useful and easy starting point.)
