need help with versapro plc programming software.
We were given a small plc from GE which uses versapro software and i am trying to use it just to set up some learning programs i have some lights, P.B. etc on a test board. problem is we have no program information and i am used to working with AB RS logic and this versapro stuff doenst seem to friendly anyone have any info for programming or helpfull advice.
RE: need help with versapro plc programming software.
Hello;
     Do you have the Versapro software? If so there is extensive online help. The main difference between RsLogix and Versapro is that Versapro is more drag and drop oriented. Also the ladder window (upper left window in the default) is sectioned into "cells". One cell can hold one contact for instance. If you drag and drop a contact over an existing one, the existing one is overwritten.
     Like RsLogix, Versapro has both online and offline modes. In order to do much of anything online, the logic in Versapro must be equal to that in the PLC. You can make the logic equal be downloading the program for the PLC or uploading the program in Versapro.
ok, i have more time on my hands now so iam going to bring the stuff home from work and see if i can make a simple program and go from there.
