How to import HecRas schematic basin back into MicroStation 2004
I used MicroStation 2004 to generate cross section data into HecRas. In HecRas I modified some of the cross section stations. Now I would like to export the schematic from HecRas and import it into MicroStation 2004. I've searched MicroStation help and HecRas help and also Googled it but cannot find a way of doing it. HecRas help insinuates it can be done but doesn't give much information on how to do it.
RE: How to import HecRas schematic basin back into MicroStation 2004
Then I get into 3d file and write the profile.
Using the 3d comands I generate a sloped surface (zero Slope) and project the written profile to intercept the ground surface.
This is the only way I have been able to do this. Maybe someone else can shed some light on to this issue.
