ASME IX - Contact Tube to Work Distance
Does the variable "contact tube to work distance" apply to GTAW welding, or is this only applicable to GMAW or other processes?
Is there a place on a GTAW WPS that you specify the distance of the tungsten tip to the work surface?
RE: ASME IX - Contact Tube to Work Distance
Where as in GMAW/SMAW there is. Ok answered my own query.!
cheers,
Simplified. Arc Gap in GTAW is not required to be controlled by ASME Section IX.
It is good practice to include the arc gap as a reference variable on the WPS in a supplementary notes section, particularly with Automated or Semi-automatic welding. For manual welding, it all comes down to the skill of the operator.
Definition of contact tube per ASME IX:
contact tube: a device which transfers current to a continuous
electrode.
One can argue that since the collet body meets this definition in transferring current to the tungsten, that it would indeed be considered a "contact tube."
QW-256 disagrees however, and is quite clear in that regard. And, since the filler wire isn't considered the electrode, it can't even apply to a hot-wire GTAW setup.
