Torroidal coil
Torroidal coil
Torroidal coil
I would like to generate a toroidal coil similar to attached image.  Must have a rectangular profile as if coil wound on cylindrical sleeve rather than true toroid.
I did manage a round profile with a swept protrusion and helix, however I am stumped at generating rectangular shape.
RE: Torroidal coil
RE: Torroidal coil
Thanks beachcomber, that looks good. However I cant open files. Could be bs a version problem.  I am using ST1
I'll look up xpress route
RE: Torroidal coil
Figured out problem with Xpressroute.  I don't have it.
I'll try Frames
RE: Torroidal coil
It's done in ST2.
You should be able to get the construction from the jpeg, and the procedure is exactly the same with the sketches with the radial lines at the top and bottom then join the ends of the 'spokes' as required
You also need to produce a part with the cross-section of the wire in it. Only a sketch is needed, you don't actually have to have a solid.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
