Within design condition?
Hi
I have a pipe system with design 75bar@110C. The pump gives a pressure of 78bar@20C and 72bar@110C due to the density charateristic of methanol. The 72bar case gives the highest usage factor. Is the 78bar case within design? For sure it is safe but what does the code say?
Regards Thompa
Regards Thompa
RE: Within design condition?
Checked some pipespecs and in that range the p/t rating decreases with approx. 15%.
You have no specs with p/t rating out there?
Thanks for the response!
