Aluminum Tubing
Aluminum Tubing
Aluminum Tubing
I often have oportunities to design aluminum lifting frames/baskets.  I typically deal with carbon steel designs and am looking for a general reference for aluminum designs.
I know that after welding aluminum its yield strength is reduced significantly along with other factors.
Can anyone recomend a general design guide for aluminium structural design for me to begin researching?
Thank you in advace.
RE: Aluminum Tubing
I think there's an Aluminum Design Manual that covers pretty much all you need.
RE: Aluminum Tubing
There are two Candian Codes
CSA S157 - Strength Design in Aluminum
and
CSA W59.2 - Welded Aluminum Construction
RE: Aluminum Tubing
Is there an AISC standard (American)?
RE: Aluminum Tubing
Jstephen already told you...
RE: Aluminum Tubing
As JStephen said....
There is an Aluminum Design Manual.  The 2010 version is out.  It is produced by The Aluminum Association.
Here is a link...
Aluminum Association - ADM 2010
RE: Aluminum Tubing
Or you could call Alcoa and they will send you one too.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
RE: Aluminum Tubing
Will Alcoa do it for free??
RE: Aluminum Tubing
30 years ago they sent mine for free, but then again, I'm special...
Mike McCann
MMC Engineering
Motto:  KISS
RE: Aluminum Tubing
Mike...I used to get the individual booklets for free (same info as in the ADM, just pieces and parts), but haven't seen any of those in years.  I've had to buy the last three ADM's I have....and they ain't cheap.
