How to save the z-component of a point as an expression?
3
Hello everybody,
I have a problem with NX 7.5.
Is it possible to get the z-component (value) of an existing point by using expressions?
For example something like: oldValue = getZCoord(point14)
(point14 is the already existing point)
Thank you very much!
Stike
RE: How to save the z-component of a point as an expression?
Not necessarily. If the point was located relative to some vertex such as the corner of a solid or the center of an arc, there will NOT be any expressions associated with the Point object, despite that fact that it's a parametric (associative) feature.  Only if it's created as a stand-alone 'smart point' will there be a series of X,Y,Z expressions.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks for the fast response.
In my case it's exactly like John wrote. I have a relative located point and I need the Z expression from it, just to compare the z-value with an other value...
Is there any other solution for this kind of problem?
Thank you very much indeed!
Could you make use of a Distance Measurement ?
NX 6.0.5.3 (NX 8 Beta)
Windows XP32
Thank you, Distance Measurement got me out of the mess!
