Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
deanmc16 (Chemical)
29 Mar 11 3:28
I have had only a few hours experience with Fortran. Despite this, I wish to run an Aspen Plus simulation using user-defined kinetics in Fortran. I have used the usrkin.f template supplied by Aspen Plus to create my own kinetics subroutine. The result is a Fortran file called ESKIN.for. I downloaded a FORTRAN editor/compiler called Plato to do this.
According to the Aspen Plus User Guide, the next steps involved in applying a Fortran user model to a simulation are as follows:
• Compile the user models using the aspcomp procedure
• Link the user models into a Fortran shared library using the asplink
procedure (optional)
• Supply the object files or shared library to the Aspen Plus system
I would greatly appreciate any assistance you can provide on how to actually perform the above steps.
For example, how and where (in Aspen Plus, in the compiler?) do I type the command aspcomp?
If anyone has an example simulation that uses a user kinetic model that they are willing to share, I would be grateful.
Thanks for your time,
Dean
Close Box
Join Eng-Tips® Today!
Join Us             Close
