Design Table ? ... maybe
If I've got a field in my FILE_PROPERTIES_CUSTOM tab - that I want extracted in tabular format to a drawing - is the best way to extract that data, with a Design Table?  Or is there another better way?  I've done searches with no luck, but perhaps I'm not searching for the correct terminology.
RE: Design Table ? ... maybe
You can insert a "general table" into your drawing.  You can set the column to display your custom property.  No need for a design table.  This may only work with the BOM table... give it a try.
-Dustin
Professional Engineer
Pretty good with SolidWorks
