tiny hydraulic line with o-ring
there are ~3/16 inch diameter steel lines on my Volvo 240 power steering rack. They look so much like brake lines I was expecting to see bubble flared fittings on each end. Instead there is a small o-ring bearing against a small shoulder or flange either formed in the tubing or perhaps brazed in place.
Is this an "official" type of fitting? What is it called, so I can order some parts?
thanks
Dan T
thanks
Dan T
RE: tiny hydraulic line with o-ring
James Spisich
Design Engineer, CSWP
http://m
Ted
It is likely proprietory to volvo, likely using metric threads.
There is a beaded tube flange used in air conditioning, larger tubes, but does your tube look like this?
http://hyd
page 45
Ted's link above is to a 'lite' version of the ORFS joint. The actual ORFS joint is much heavier and higher pressures. We use ORFS almost exclusively, but I didn't know there was a 'lite' version for lower pressures and lower costs. Learn every day.
kcj
