How to export zip assembly
I am facing problem in exporting assembly files using zip assembly, I am using UG NX3
followed all procedure in installing as given in earlier threads
Problem
1.    not able to select assembly or part
2.    When I press select window will disappear.
RE: How to export zip assembly
I just tested my version of NX 3.0 using the Zip Assembly function (which I installed sometime ago) and it's still working just fine.
Have you set up your 'user defaults' folders properly?  In the 'startup' folder you should find the 'ugzipc.dll' and 'ugzipc.men' files and in the 'application' folder you should find the 'ugzipc.dlg' file.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks for response,
I have set as you have mentioned, the moment i click select part, dialog box disappear...:(
I'm sorry but that abour exhausts my ideas on this.  Do you have any other NX Open programs that you could try running as somehow the system may be having problems with any sort of external program?
John R. Baker, P.E.
Industry Sector
Cypress, CA
