controling number of decimals in equation
I've created an area calculation equation to project on drawings sheet for every sheet metal part ... but the problem is that I can't find a way to control the number of decimals as sometimes the value show 7 digits after 0.
RE: controling number of decimals in equation
-handleman, CSWP (The new, easy test)
here's my equation if you can elaborate:
"Area"= ("SW-Volume" / "Thickness" ) * 0.00694444444
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
