Linking Part length x width into bill of materials
Hell everyone this is my first post here and to start I am an engineer for a furniture manufacture where I was brought on to create libraries and to improve production times.
With that information stated I would love to be able to create one standard component (file cabinet, etc.) and just modify the size using a design table then insert into a drawing and have the bill of materials list each component (ends, rails, top, bottom, etc.) as well as there length and widths.
I draw each part with the cut dimension then add a .125" banding around the edges but do not merge the two. I do this so I can get the cut dimensions to put into another software to create cut lists and also to make drafts to show customers and management.
My question is how can I link the length and widths of the cut dimensions and also the overall dimension into the bill of materials?
I am new to design tables and bill of materials but am fluent is drawing parts within SW. Any help would be appreciated.
RE: Linking Part length x width into bill of materials
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
-Dustin
Professional Engineer
Pretty good with SolidWorks
Save this as a part template, 'whatever.prtdot' and use this as the starting point for all you panels.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Go through the weldment tutorial in SWX as well.
