building a brick wall from inside in multistorey construction
Hi all,
In multistorey construction, are there methods used to construct a cavity brick wall from inside the building, achieving a similar quality finish using traditional methods of scaffolding etc.
I'm thinking of a hypothetical situation where a building is sandwiched by two vacant site however permission has not been granted to use the neighbouring land.
RE: building a brick wall from inside in multistorey construction
I'd only recommend this method if the wall cannot be seen.
Could you fix a scaffold to your building without supports on the ground? or is airspace an issue
Kieran
