Auxiliary Views in Drawings
I've been trying to figure out how to add a view that is parallel to a plane cutting through the corner of a rectangular part.
The first image is not what I want. The auxiliary view only shows a view without the third face sticking out, resulting in a view that does not look straight down the hole.
The second image is the one that I want in the drawing.
The third image is an example of what I'm looking for.
Any help would be appreciated.
(Running SolidWorks 2009 through 2011)
RE: Auxiliary Views in Drawings
Thanks for the suggestion.
TheTick: Could you elaborate? I've tried multiple layers of projections but none have given me a view perpendicular to the plane I want.
I won't be able to try until Monday AM.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
http://www.EsoxRepublic.com-SolidWorks API VB programming help
