Pro/Piping Solid not updating to route
I have Pro/E WF 4 with the piping application. I am updating an older piping assembly. Some of the pipes are being routed to different ports. I am able to get the route to appear right (blue line goes where it should), however the solid does not update to the route. I end up having to delete the solid part out of the model and memory, and start over. This destroys the associated drawings and assemblies.
So, is there a way to get the solid hose part to update to the new route?
