Novel boat drive - engine in the front
Generally:
1/ Aircraft have center of mass in front of center of drag for stability . . .
2/ Boats have engines in rear thus center of mass is behind center of drag
but not in this boat ? ?
http://www.jdfab.com/jbarritt/hotboat.htm
Comments please.
Comments please.
RE: Novel boat drive - engine in the front
Shallow lake? I.e, no flotation required?
Looks like great fun.
Mike Halloran
Pembroke Pines, FL, USA
When you wrote "novel" and "front engine" I thought you were going to describe a boat with its propeller on the bow. These were tried in some speedboats in the 1930s - presumably they were non-planing hulls.
With your boat I don't think you can have the engine weight so far forward and still have a conventional planing hull.
Aircraft travel through one medium only. Boats travel on the air water interface so the lift drag characteristics are very different on the top and bottom surfaces.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Weighs next to nothing, as engines go.
Mike Halloran
I'm mostly concerned with the exposed driveshaft to catch your feet on.
Weight distribution and shaft angles and line of thrust vs centre of drag and centre of lift at various speeds are much more of a concern.
Pat
for site rules
If you are using a motorcycle engine in a boat you can have a chain drive from the engine down to the propellor shaft running under the engine - this also allows a shallower angle on the shaft. I have seen this arrangement a few times on small hydroplanes.
Which reminds me - three-point hydros often have the engine well forward above the sponsons -although rear-engine hydros seem to be increasingly popular.
If the shaft angle is to steep it drives the nose down, if it is to shallow, it drives the nose up.
If the shaft axis passes through the hull to far forward, it lifts the nose, if to far back it lifts the tail.
The gap between the floor, the inside edges of the sponsons traps air and creates a ground effect. Trim angle of the floor determines mount of aero lift and longitudinal position of the sponson in contact or very close to the water surface controls where the lift applies.
If hydrodynamic lift is to great at the front the front lifts rapidly then stalls and falls, creating a porpoise like motion. Same if there is unstable suction at the back.
If aero lift is to high at the front the front climbs then as the angle of attack increases the lift, especially at front increases until the boat kites and becomes airborne and comes down upside down from a back flip or barrel rolls. These are the shots that make the news.
On a race boat you want the maximum aero lift you can get without exceeding the boat weight, so you maintain a minimum safe weight on the water surface. Waves and head winds both work against maintaining that balance and that is the razors edge of flying these machines.
Pat
for site rules
Mike Halloran
