Conditional pictures
Does anyone know if (and how) it is possible to link a picture (or embedded object) to a formula, e.g. an if statement?
This way it could be possible e.g. to show one picture if cell a:1=1 and another picture if cell a:1 = 2.
Any suggestions?
Mogens
Any suggestions?
Mogens
RE: Conditional pictures
In
A4 select Insert/hyperlink select the file that contains the picture you want displayed as picture1
A5 select Insert/hyperlink select the file that contains the picture you want displayed as picture2
make
A1 =CHOOSE(A2,HYPERLINK(A4,"picture1"),HYPERLINK(A5,"picture2"))
In A2 put 1 or 2, in A1 it will say picture1 or picture2
If you move over A1 the little hand will popup single click and you'll open the picture.
If you want the picture to be displayed automatically without clicking on the name in A1... that's another price (don't know how to do it yet...).
HTH
Saludos.
a.
If you place a macro in the "ThisWorkbook" object (in VBA) you can accomplish this task quite easily:
Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
Variable = Range("A1").Value
Select Case Variable
Case Is = 1
Worksheets("Sheet1").Shapes("Object 1").Visible = True
Worksheets("Sheet1").Shapes("Object 2").Visible = False
Case Is = 2
Worksheets("Sheet1").Shapes("Object 1").Visible = False
Worksheets("Sheet1").Shapes("Object 2").Visible = True
End Select
End Sub
When you change the value in cell A1, the picture corresponding to your entry will appear (enter 1 and "object 1" appears etc.). Other than that, I'm really not sure how to make your pictures appear and disappear.
Hope this helps!
jproj
This was exactly what I was looking for
regards
Mogens
