Image Quality Changes
When I work on parts with curves and arcs the image quality changes on it's own when I edit a feature. I have the image quality set above the "Low" setting and the "Optimize edge length" box checked. I edit a feature or a dimension and the image quality resets itself back to "Low" and the "Optimize edge length" box becomes unchecked. Why does the image quality change by itself? I have attached an image of a part example. I have been dealing with this for quite a long time now and it is very frustrating. Any help is appreciated. I am running SolidWorks Professional 2010 SP4.0 on a XP, 32-bit workstation. My graphics card is nVIDIA Quadro FX 3800.
RE: Image Quality Changes
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
I am having the same problem. Our VAR reported to SW as a SPR.
(SPR 562846: Image quality of this part file is automatically set to low when opening assembly drawing file and rebuild (Ctrl+Q) it.)
It is listed as high impact so hopefully this bug will be fixed right away.
Hope this helps,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
Mechanical Designer
If first you do succeed...try something harder.
Blair H.
SW 2009 sp3.0, HP x4600
3.16ghz Intel Core2 Duo,
3.0 GB ram,
Nvidia Quadro FX 1700
Space Pilot Pro...they ROCK!!
