Noncontact hardness testers, looking for recommendations
I am looking for a portable, noncontact, hardness tester that I can use to measure the Rockwell of saw blades.
I found a couple online but I can't find anybody to give me a quote.
So I guess I'm looking for a unit as well as a knowledgeable, responsive source.
I appreciate any help you cared offer.
Tom Walz
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
RE: Noncontact hardness testers, looking for recommendations
I.m assuming that you are referring to not leaving an indenter mark. If you want no contact at all then Eddy Current is the answer.
Here are three approaches to the problem.   The first is the Eddy currant probe.   I'm not sure about the Richter instruments which are rebound instruments and may or may not leave a mark.  The third is the Ultrasonic hardness tester,
i haven't personally used any of this type but have been around to check the results on the Eddy Current type and the Richter.
http://www.ibgndt.com/eddynomic-eddy-current-test.htm
http://www.precisegauge.com/index.php?main_page=product_info&cPath=88&products_id=313
http://www.phase2plus.com/hardness-tester/pht-met.htm
Rebound and Ultrasonic (UCI) types leave indentations. The size of the indentation obviously depends on the applied load, but leaves one nonetheless......
Cant comment on eddy current testing
Declan
Thank you gentlemen,
Strangely enough I was told that rebound and ultrasonic types do not leave an indentation.  Once I pressed the person a bit, the answer became more along the lines that they do leave an indentation but nothing like the conventional testers do.
Thank you for the heads-up,
Tom
Thomas J. Walz
Noncontact hardness tester is a contradition in terms.  However, some methods (rebound, Microdur) leave very small marks and can be considered 'nondestructive' for practical purposes.
There may be methods that can tell you hardness is OK by somehow detecting another property that correlates with hardness.
