Effect of Backslope on Retaining Wall
I have a stacked block gravity retaining wall with a 10 degree backfill slope. When I am calculating the pressure on the wall from the soil what height of backfill do I use?
htt p://files. engineerin g.com/getf ile.aspx?f older=a82a 355d-6fd6- 45bf-b103- 6a682faa3f 36&fil e=20110324 135231.pdf
htt
RE: Effect of Backslope on Retaining Wall
Find a good book or Google retaining wall calculations.
Backslope angle is Beta in the equations.
You will also need to check the overall stability of the slope.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
If it is an MSE wall and your using NCMA design then the Ka value will be calculated using Coulomb equation which will reflect the backslope condition and therefore your height is H (the total height of the wall at back of wall).
Also see NCMA's Design manual for segmental retaining walls.
EIT
