Tunnel Ram w Two Propane Mixers
Hello, I read your thread about tunnel rams addressing problems and fixes with dual mixers. Terms like "too radical" were used, though I found this confusing as Tunnel Rams require running higher RPM's anyway. My question is: in the end is it a waste of time setting up this system over just using two carburators?
I'd like to set up two 425 Mixers on a tunnel ram on top of a 350 with a cam lift of 447, 223@50 der.cam, the truck is standard. Id like to run this rig on the street and strip. Id like your opinion before making further investment into this system. Thanks. thread71-37133: propane for high performance
