Failed Connections in an Assembly
Greetings, all! I'm kinda new around here, but not new to Pro/E...although some days it feels that way!
Anyhow, I have an issue where I am assembling a conceptual solenoid-linkage using connections. However, they are failing to some extent.
Here's the description of what's going on in the picture: The pink gear is assembled to the shaft using Cylinder. It moves axially 22.225mm and rotates 360 degrees freely.
The blue trunnion collar is assembled to the pink gear using Cylinder and moves along with it. It is also Aligned to the centerline and Aligned from its bottom surface to the top surface of the pink gear.
Next, the green bar is assembled using Cylinder at the fulcrum, and then to the blue trunnion collar using the Slot connection.
With these assembled, I can hold down Ctrl+Alt and pick the green bar with the L Mouse Btn, and the linkages and gear will move up and down like I want it to.
Now, when I assemble (or attempt to assemble) the solenoid plunger to the other slotted end of the green bar, the whole assembly fails to move as it should. Seems like the connections are fighting each other and it's frozen.
I've tried every combo for the other slot: Bearing, Slot, etc. to no avail.
Any suggestions? Let me know if you need more details...
Thanks and best regards,
Edward
EDIT: I attempted to upload a JPEG of my system, but I think it may have failed. PM me for an email copy...
Edward
RE: Failed Connections in an Assembly
