Image or PDF in the drawing
we buy a motor from a supplier that has give us the drawing in PDF.
I want produce our drawing inserting the PDF or the image in our specification.
I haven't found the manner to insert the PDF, but the image yes.
Anyway the image is present, but I can see it.
See the image attached.
Solutions ?
Solutions ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Image or PDF in the drawing
Or try the layer visible in view button and reset layer settings.
Best regards,
Michaël.
NX4+TC9 / NX6+TC8Unified / NX7.5 native
thank you for the solution, but nothing.
The image in the specification is not visible.
Thank you...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
when I'm in the specification I do Insert->Image.
I don't see the image (.PNG), but with the GIC I export the PDF of the specification and the image is visible.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thank you...
I was limiting my comments to what can be done inside of NX and NX only. You can add an image to the face of a Drawing, but that image can only be in JPEG, PNG or TIFF format. Those are the only image formats supported. PDF is NOT an image format but rather a digital document standard.
John R. Baker, P.E.
Industry Sector
Cypress, CA
maybe my English is not so clear, but I wrote that I put a .PNG in the specification (drafting).
The PNG is not visible as the image attached before.
If I export the specification to PDF via TeamCenter GIC tool or via File->Export-PDF NX command, the image is visible.
So in my first post I asked if there is a command in NX that permit me to put a PDF in the specification as OLE object and why I can see the image in the specification.
Thank you...
Best regards,
Michaël.
Thank you...
Or convert it to a jpeg.
Best regards,
Michaël.
See attached image.
Thank you...
Best regards,
Michaël.
Thank you...
Insert -> Image...
...on the face of that drawing, as shown in the attached image.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I resolve if the specification is in monocrome.
Monocrome specification can handle unassociated dimensions that in colored specification has different color ?
Thank you...
