Plate SA516 Gr 70
Plate SA516 Gr 70
If Not mentioned in certificate, What is the minimum Metal Temperature of plate SA516 Gr 70 (not normalized/ not impact test)to be considered?
RE: Plate SA516 Gr 70
MDMT shall be determined by UG-66, your case of SA-516 Gr. 70 Not Normalized - acc. to carve 'B' for relevant governing thickness.
(ASTM A-20 TABLE A1.15 indicates "Generally Available Grade-Thickness-Minimum Test Temperature Combinations Meeting Charpy V-Notch Requirements Indicated (Normalized or Quenched and Tempered Condition)" - but tab's values are NOT materials minimum design metal temperature).
Thickness is 18 mm and MDMT specified from client is -10 Degree C.
We got the material but certificate not mentioned the Min.Metal Temp, and client forced us to mark in certificate.
