Simple Volume of negative space/ volume of the fluid in a pipe
Do I have to use FloXpress Analysis wizard for the Subject matter?  COSMOS?  Or is it much simpler than all that?
RE: Simple Volume of negative space/ volume of the fluid in a pipe
Maybe if you can explain what negative space is, we'll have a clue what you're talking about...
Mike Halloran
Pembroke Pines, FL, USA
All I meant by negative space is - just not the physical part itself, not the material.
I don't remember if FloXpress reports the internal volume of a cavity.  Certainly it could, and it's not difficult to use, once you get the hang of it.
Or you could subtract a copy of the part from a non-hollow solid with the same exterior geometry, yielding a new solid with the volume of the original object's interior.
Or... I think there are some plastic- molding oriented commands that can generate or report internal volumes.
Mike Halloran
I think by negative space you mean the volume of a cavity. Using a CFD code to find a volume like this is overkill. If it is a pipe, cap both ends with a planar surface and knit to form solid.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
Thanks kellnerp - How do you access properties of knit solids?
(I don't know surfaces very well.)
Look in help for Knit Surface.
All solids in SolidWorks are knit together from surfaces. A solid has two properties that set it aside from surfaces. The surfaces in a solid form a "water tight" volume and all surface normals point out from the inside of the volume.
The knit command has an option to form a solid if the surfaces included in the selection list comprise an enclosed, "water tight" volume.
TOP
CSWP, BSSE
