Pressure vessel design reality check
Hi everyone,
I am looking for a quick reality check. I have some background in pressure vessel design, but we always used APV for calcs, and only worked up to 150 psi. Well I have had a friend ask me to design a one off filter unit for him, to handle 5000 psi, and was hoping to get a quick look over my wall thickness calcs.
I am using the formula t=p*Ro/(Stress allowable + 0.5p)
Using 5000 psi
3.5" OD
SS 316 with a UTS of 80,000psi
FOS 4
I am getting 0.389" wall thickness.
Can anyone comment on my calcs and let me know if I'm making sense?
Jim
Using 5000 psi
3.5" OD
FOS 4
Jim
RE: Pressure vessel design reality check
When I use the rules for B31.1/B31.3 piping design, with an allowable stress of 20,000 (no corrosion/threading allowance etc) I get almost the same number.
Why are you not using the rules of ASME VIII ?
If you use ASME Div 1, the forumla to use shall be the one for heavy wall. However that does not change the results much.
MJ, I'm not using Sec VIII, because I am no longer working in the pressure vessel industry and don't have a copy of it. Also, this being a one off design, that isn't being used for commercial use, or being sold, I have no requirement to follow any specific code. It's for a scuba compressor, and most other HP air products I have dealt with have used 4:1 FOS, so I felt pretty comfortable with that, especially being made from SS, rather than the aluminum that most filter housings are made, I am not too worried about sustained load cracking or fatigue..
James, you are correct it is based on pipe, and I am looking to use 3" XXH which has an OD of 3.5" and wall thickness of 0.6", so there is plenty of room for tolerance issues. I am planning to thread the pipe internally, and turn SS end plugs using O-Ring seals, and obviously use the correct OPV and associated plumbing.
I think I will continue with my design using Sched 160. I had originally thought XXS might be good, because I have to thread the tube, and it is being used in a moisture separator so it will have the potential for corrosion as well.
Jim
