"Shaded with Edges" view shows blue edges
I have received this part as .stp from the manufacturer.  When I have it displayed such that edges show (eg: "shaded with edges", "hidden lines removed"... etc), they are BLUE!?  How can I change them to BLACK? It is like this both in the .stp format and also when I save as .sldprt.
Screenshot attached.
RE: "Shaded with Edges" view shows blue edges
The edges are blue because you have a part that is made up of a bunch of unconnected surfaces.  Select everything and try to knit them together.  If you hold your tongue right everything should go black after forming a solid body.
Dan
www.eltronresearch.com
Dan's Blog
The blue edges indicate that the surfaces are not knitted together and are not 'watertight'.
Brilliant, thank you!
