led persistence
led persistence
led persistence
if a 20ma rated led is pulsed at 20ma, how often (frequency) would it have to be pulsed to maintain the illusion that it is on continuously? or do i have to pulse it harder (>20ma) to give the illusion?
RE: led persistence
Depends upon the person... do you see your TV flicker?  What about a fluorescent bulb?  What frequency are they updated at?  Those are good starting points...
Dan - Owner
http://www.Hi-TecDesigns.com
RE: led persistence
Also depends on if there is any motion.  We used to install an LED temperature readout (gage) in an IC engine installation.  Problem was you couldn't read it in some installations, due to excessive vibration and the fact that the led's were flickering at some 10 or 15 hz.  Lovely moire pattern, though.
RE: led persistence
bt,
I would have expected an annoying flicker without vibration at that refresh speed winky smile  If vibration or motion is expected, I'll shoot for double the standard refresh rate.
Dan - Owner
RE: led persistence
I had a project with a LED power on indicator. Hooked it to an extra pin of a PIC.  It was sending out data all the time at 300 or 600 baud.  No one ever noticed it flicker.  Had a little cup pickup with a photo diode in it to place over the indicator.  Easy way to get data out without turning a screw.
RE: led persistence
let's say i go with 150Hz. any thoughts on duty cycle? if i pulsed 20ma at 5% d cycle, would the led appear as bright as it would with 20ma steady DC current?
RE: led persistence
LEDs manufacturers publish graphs of brightness versus current and pulse currents allowed. An LED at 20mA and 5% duty cycle is not going to be as bright as one running at the same steady d.c. current. The trick is to work out what higher pulse current - within the maximum pulse current and overall power dissipation allowed - gives you the same mean power as the d.c. current for the brightness you require.
For an "ordinary" LED you may well find that you can't get the brightness at the duty cycle you require without exceeeding the maximum pulse current. Consider hyper-bright LEDs from manufacturers such as Avago - really bright on just a few milliamps. (Usual Disclaimer)
RE: led persistence
ecreek,
What is the final application?  Certain types of LEDs can be pulsed at higher than rated currents for short time periods and give a perceived increase in brightness compared to their average DC power.
Dan - Owner
RE: led persistence
final app would b what is already on the market...scanning dot matrix indicator signs. this is mostly a project for therapy reasons...just as my occasionally repairing an analog tv to keep in practice. on an aside, over the years, i have noticed that if i flick my eyes from side 2 side while directing my gaze to a lit digital readout, i would see superimposed (side to side) replicas of the readout.  from this i calculate that the refresh rates are ~ 60Hz (plus or minus many many % because i have a preconceived notion that refresh rates are from 30 to 120hz)
RE: led persistence
Refresh rates are a function of eye persistences as well as source persistence.  TV phosphors used to have about 10-15 ms of persistence, so 50 to 60 Hz field rates worked well.
However, LCD displays currently have about 8 ms of persistence, so LCD frame rates need to be much high to mitigate flicker.  LEDs basically have no persistence, which can often be seen on LED brake lights or traffic lights.  When they're turned off, it's immediate and abrupt.
TTFN
Chinese prisoner wins Nobel Peace Prize
RE: led persistence
There's data and recomendations from LED manufacturers about this.  I'd contact Avago.
RE: led persistence
Running short duty cycles may mean you're running much higher current than the rated maximum.  This means you have to be careful that whatever you're driving them with can't crash and leave them on..
Keith Cress
RE: led persistence
Contrast ratio of scene may also have an effect , I have witnessed Auto brake lights flickering in the dark ,with the motion of a passing vehicle ,worstened by turning your head  " Giving impression  of more than 1 vehicle " (NOT impressed !)
RE: led persistence
Agree with zzzjim.  Newer Cadillacs using LED tail/brake lights seem to stobe them in tail light mode but not brake light mode.  Very distracting and kind of the opposite of what you'd really want.  Then again I'm rather sensitive to flicker.
