Planetary gear for a bike type application
Hello! we are contemplating a new gearing design for one of our products, and are looking to use a planetary gear- but we are kind of blank with regards to where we can find a good producer (high volume low price) and potentially a standard product.
It is a fixed gear 6:1 palnetary transmission. attached is a crude sketch of the mechanism.
The drive sprocket (1) is driven by a chain, and is transferring force to the planetary gear. the Planetary gear (3) is a fixed gear ratio mechansim, with a gearing rate of 6:1- one revolution in (from the drive sprocket(1)) gives 6 revolutions out on the driving axle (2).  we can use gearing ratio of up to 8:1 if there is a good reason for doing so.
the driving axle (2) is going through the panetary gear mechanism, and is layered on both sides of the planetary gear in ballbearings (4)
the output torque is normally 10-30Nm, it is a man driven mechanism driven by a lever, so the usage is irregular with shifting forces. since it is coupled to a lever, it wil be activated from 40-100 times a minute with a input motion (on the drive sprocket) of 1/2 to 3/4 of a revolutions per activation.
Other specifications
max width- 45mm,
max. diameter (height) 110 mm,
max. weight 400 g
lifetime w/o service- +3000h
efficiency- +95%
drive axle diameter 10-12 mm
lower weight and size and cos as well as higher strenght/ efficiency is better :)
lower weight and cost is more important than smalle size
would be VERY thankful for help and or leads
/jonas
RE: Planetary gear for a bike type application
If cost and weight are more important than size, could you just use a conventional spur gear arrangement?
yes that would be an alternative.. than the bigger cogwheel should be maximum 140 mm in diameter, and the width maximum 30 mm.
would it be possible to make such a gear lighter than a planetary gear?
jonas---Chief-Mover---Me-Mover APs----www.me-mover.com
Thanks- I'll call them tomorrow! /j
I'm not understanding why you need a planetary gearset at all;  seems like you could get 6:1 simply with sprockets.  Top gear on a 18-sp bike is pretty darn close to this.
