Resonance/frequency and sounds
I am hitting glass plate with high power ultrasound. The ultrasound pulses are 1MHtz pulsed at 1KHz.
As a by product, we are getting an audible component, a high pitched ringing. As we change the pulsing rate, say over the range of 0.5KHz to 2KHz, the pitch that we hear changes.
Why is this? I was thinking it was the natural frequency at first, but since its changing with frequency of the pulsing, it cant be.
thanks
thanks
RE: Resonance/frequency and sounds
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Based on that assumption, I suspect at the high frequencies of your excitation, the modal density is large (lots of different modes closely spaced). The presence of an excitation rich in harmonics (periodic pulses) compounds the situation because you have many exciting frerquencies at one time -> more chance of hitting a resonance. Bottom line, you have lots of excitation frequencies, lots of resonant frequencies, and you are hitting (amplifying) different resonant frequencies (and mode shapes) as you vary frequency.
(2B)+(2B)' ?
Is your 1MHz pulsed on and off at 0.5kHz to 2kHz?
Audible frequencies are between 30Hz and 20kHz. You cannot hear ultrasound, which is why it is called ultrasound. Even us middle aged rock and roll fans can hear stuff at 0.5kHz to 2kHz. When you change from 0.5 to 2kHz, you should hear a change of pitch. There may or may not be resonance happening. Definitely, there is a forcing function.
What you hear is your pulsing.
(2B)+(2B)' ?
Cheers
Greg Locock
It seems like there is a resonance that is building up and going to a higher pulsing frequency cuts off this build up.. but this doesn't explain the change in pitch.
this is a very high pitch noise, id guess over 10kthz, its high enough that the older people like me cant hear it so its on the upper end of the audible range..
http://
Is the resonance related to the piezoelectric transducer or the lamb wave.. something for me to think about for tonight while im in bed.
Cheers
Greg Locock
Does the pitch vary with your pulsing frequency, or does it vary some other way?
there are some increases in the harmonics (overtones) that i can see via FFT in matlab..
the hydrophone through air is recording the 1MHz pulsing at 1KHz.
its probably just a combination of both. thanks everyone
