Hole Wizard
Hole Wizard
Are the values that come up when you click the hole wizard in NX5 stored in an editable file somewhere? I would like to adjust the values to our own standards.
Thank you.
Thank you.
RE: Hole Wizard
Insert -> Design Feature -> Hole...
...YES there is. Go to where your NX software is installed and in the...
...\UGII\modeling_standards
...folder you will find the .xml files where the hole specifications are stored and which are used by the software. If you're careful you can edit, either by removing or adding additional records, what the user is presented with and what the software will use when creating a Hole feature.
Good luck.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: Hole Wizard
RE: Hole Wizard
We use several custom threads that we add to the "thd_metric.dat" and "thd_english.dat" files saved to a network location. They are pointed to using a customised "ugii_env.dat" on each machine, which points "UGII_METRIC_THREADS" and "UGII_ENGLISH_THREADS" to the network locations of the above files so everyone uses the same files. Works very well, but only for the 'Thread' function.
While I can edit the threads used in the 'hole' function (as described by John), I cannot find the appropriate pointer in "ugii_env.dat" to allow everyone to use a single networked location. Therefore we do not use the hole function, but extrude or revolve all holes and add a thread using the 'thread' function (linking the 'p' number for the tapping drill diameter of the thread to the sketch for the hole). Works well, but does anyone know the variable I need to set so we can use the hole function from a single network location?
RE: Hole Wizard
...UGII\ugii_env.dat
...file which will override the internal NX setting.
The variable is:
UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR=<path to the folder where your edited versions of the .xml files are located>
John R. Baker, P.E.
Industry Sector
Cypress, CA
