water hydrocarbon separation in reflux drum
Hello!I work in Crude distillation unit.We have a small problem regardind the separation betwen water and hydrocarbons in reflux drum.The water is sent to sour water stripping unit with a high content of hydrocarbons.The reflux drum is a simple vessel as attached.We have a pH analyser that is coted with hydrocarbon and something that looks like soot.When is clean gives a reliable indication,but when coated the pH value rises.Do you have any suggestionfor a better separation?From where does this "soot" come?
Thanks for the help!
RE: water hydrocarbon separation in reflux drum
