high pressure pipe
high pressure pipe
high pressure pipe
hi,
1. is pipe SA 106 grade B also available in welded? (a seller propose me this pipe)
2. is it allowed by ASME std. to use pipe A 53 gr.B welded, for  55 kg/cm2 steam line?
regards
RE: high pressure pipe
ASTM A / ASME SA 106 pipes are only seamless
thanks to ione & zebmahar for reply
- pipe diameter 12 inch. & sched 80
- is it recommended to Radiography Tested pipe SA 53 gr-B and use for 55 kg/cm2 steam line?
REFERENCE ASME B31.3 2008
APPENDIX K ALLOWABLE STRESS FOR HIGH PRESSURE PIPE REFERENCE TO SPECIFICATION INDEX FOR APPENDIX K PAGE: 260,
NOTES FOR APPENDIX K TABLE 261.
TABLE K-1 ALLOWABLE STRESS PAGE 262 FOR A53B, A106B
L S THILL
No pipeclass/spec?
europipe (Chemical)
pipeclass/spec: API RECOMMENDED PRACTICE 14E (RP 14E)
