Files failing to open.
Hello, I am an engineering intern, just starting to use Ansys.  Today i did analysis on a few objets I made in solidworks.  I saved the files and then tried to reopen them.  When I tried to open them I got the following error messages:
Error! Data entity not found: /Schematic/System:SYS 1
Error! 'GuiOperation ProjectSchematicView.CellSelectionChanged' threw exception during Invoke: Data entity not found: /Schematic/System:SYS 1
If anyone knows a fix for this it would be greatly appreciated.
RE: Files failing to open.
That sounds like one for ANSYS tech support. Check the directory tree and see if the files are even there. Usually I like to export things from CAD as a parasolid and do my preprocessing in DesignModeler. That might be a workaround.
