NX6 move command
NX6 move command
I have a parasolid body that I want to step along a linear path, so that I can observe it at it passes thru a hole in another body.
Stepping along a path, using a body like this, would have been easy using "transform", just specify the direction and distance, and press "apply" after every move and watch it go.
This is a major pain to do using the "move" command, because after every move (or step) EVERYTHING has to be refspecified.
When using the "move" command is there a way to retain everything that it previously used?
What am I missing here?
RE: NX6 move command
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
