Strange sketch behavior
I have a new file I created with strange sketch behavior. I tried extruding sketch and it shows gap on one corner. I verified there is coincident constrain and modeling tolerance is set to .0001. Still when zooming in there is gap visible (see attached picture). Part cleanup is not helping. Any suggestions what might be wrong? Thank you.
NX3 + TC9
RE: Strange sketch behavior
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Sketch is extracting as sheet body. I also noticed that when looked at from angle it appears not to be planar with plane used to create it. (see picture)
Thank you for fast response.
NX3 + TC9
Both are lines and they were drawn fresh (not projected). Entire sketch is in shape of simple D letter (half oval) and it appears that somehow one line end is not on the sketch plane. I can even measure angle of the sketch plane
NX3 + TC9
John R. Baker, P.E.
Industry Sector
Cypress, CA
If u have still doubt whether the end points are coincident or not, you can always check with Analysis->Measure Distance and select the end points of respective lines, you will find that the end points are coincident.
Lines were drawn as sketch curves.
I eventually recreated the sketch to get it to work.
Man2007,
I can measure distance between them (it is bit over .002) and sketch fails to extrude into solid, so it is not a problem with just graphics display.
NX3 + TC9
